UI styler and journal programing
elletheman
SE
I made a simple UI and want to control 2 parameters in the expression list with it.
Im not so familiar with journal more than recording and changing values so if someone could help it would be great!
When i do a recording changing the values it looks like this
' NX 9.0.0.19
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: Tools->Expressions...
theSession.Preferences.Modeling.UpdatePending = False
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Expression")
Dim expression1 As Expression = CType(workPart.Expressions.FindObject("Stalldon_Kort"), Expression)
Dim unit1 As Unit = CType(workPart.UnitCollection.FindObject("MilliMeter"), Unit)
workPart.Expressions.EditWithUnits(expression1, unit1, "100")
Dim expression2 As Expression = CType(workPart.Expressions.FindObject("Stalldon_lang"), Expression)
workPart.Expressions.EditWithUnits(expression2, unit1, "200")
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
Hi.
In your VB code you will find a function called "update_cb" and it looks like this:
Code:
'Callback Name: update_cb
Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
    Try
        If block Is Lyft Then
        '---- Enter your code here -----
        ElseIf block Is Vipp Then
        End If
    Catch ex As Exception
        '---- Enter your exception handling code here -----
        theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
    End Try
    update_cb = 0
End Function
The way it works is when the user changes a value on your dialog the update_cb will be executed. Then the If statement will decide which block it was that was changed. You need to then supply the code to execute when that block was changed (where the ---- Enter your code here ---- comments are).
Using the code in your recorded journal between the "Menu: Tools->Expressions..." and "Menu: Tools->Journal->Stop Recording" as a template, create the code to update the required expressions when each block changes.
Graham Inchley, Systems Developer.
NX6, NX8.5(testing)
