UG NX rotate and Zoom Lags
Go to the Visualization Preferences and have a look at the settings over there.
On the Tab "Large Model" you can start with setting the Fixed Frame rate.
On General Graphics you should disable translucency and Line Antialiasing.
Other settings you just have to play around with.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
This may be related to incorrect video card drivers or settings.
I've seen this when using the "base" 3D profile of Nvidia card drivers.
Thanks Working fine now @NutAce
I am in learning ZONE
