I have a design that must be PED approved which contains a 5x3"NPS eccentric reducer fabricated from wrought Inconel 625 (spec B366). The manufacturers drawing for this reducer, while not fully detailed, has enough detail to indicate that the largest half-apex angle is nominally greater than 30deg. The PED inspector is pushing back on our standard calculations for this component based on this angle being greater than 30deg.
In looking at UG-36 where I see this angle addressed, it looks to pertain to shell components made from plate. Do these requirements apply to fittings made from wrought alloys? If not, what section (if any) would this component fall under?
