I am testing products in a swimming pool-type test facility in which self-priming pool pumps pull water from a bottom drain and discharge to a submerged level in an open tank. There are no other sources/discharges. The test is to suddenly block the bottom drain. The tested products are designed to eliminate the ensuing suction pressure drop as fast as possible. Air entrainment is an issue and I am set about to measure and record the amount of air that enters the suction side.
To measure, I drain and cap the suction pipe and evacuate with a vacuum pump to the level I expect to see when the drain is blocked (24-27 in Hg). I calculate a figure in cubic inches per minute.
My question is, what is a normal, allowable, suitable, etc., amount of air to enter such a system? Is there a rationale for a benchmark?
