EngWade
- Aug 5, 2009
- 64
Why are tie rods often times specified with hydrant installations? As an example, suppose you have an 8" water main, and you tie into it with an 8x8x6 Tee Joint. Then between that Tee and the Hydrant, there is typically a gate valve installed. My question is, why are tie-rods specified around this gate valve? In the past, I've seen it done with "anchor pipes." Could someone shed a little light on this, and explain if there is any real difference between the two?
Thanks a lot for your help.
