Aug 13, 2002 #1 insraped Mechanical Joined Aug 13, 2002 Messages 2 Location US I have a 1995 Nissan Quest with a V6. Is there anywhere I can find the dimension of the crankshaft throw? If not does anyone know the typical radius of a 6 cyclinder crankshaft throw? Thanks in advance.
Aug 13, 2002 #2 ivymike Mechanical Joined Nov 9, 2000 Messages 5,653 Location US Typically crank throws in cars are about 0.5*bore, +/- 15% When you say "crankshaft throw" you mean 1/2 stroke, right? Carpoint says that your stroke is 3.14 inches, so your crank throw would be 1.57 inches (39.88 mm). http://carpoint.msn.com/vip/engines.aspx?modelid=2191&src=vip You might want to double check that figure elsewhere; carpoint is often wrong. Upvote 0 Downvote
Aug 14, 2002 Thread starter #3 insraped Mechanical Joined Aug 13, 2002 Messages 2 Location US That's awesome! Thanks so much for the pointer. That is exactly the info I needed. Thanks, Pete. Upvote 0 Downvote
Aug 14, 2002 #4 GregLocock Automotive Joined Apr 10, 2001 Messages 23,885 Location Orbiting a small yellow star Are you sure you want half the stroke, or do you want the clearance radius of the crank? Cheers Greg Locock Upvote 0 Downvote
