I am confused by all of the features normally found on a "typical" control valve actuator. To keep this post simple, I am referring to the traditional diaphragm actuator type represented in the link. The purposes of the diphragm, spring, and actuator shaft are obvious. However, if all I'm doing is regulating pressure with a simple feedback loop, the remainder of the components—the yoke, spring adjuster, travel indicator and scale—seem to be added features only and not necessities.
I normally only work with diaphragm block valves on bioprocessing equipment. These valves typically have spring-loaded diaphragm or piston actuators. Aside from the fact that this type of valve is not best-suited for throttling, is there a good reason why it couldn't be throttled if the air pressure sent to the actuator is controlled via an I/P controller? We are using a Gemü 650 (click here for internal view), and it can supposedly be used in the just the way I've described (direct-acting only, pics show reverse-acting).
Can somebody please explain to me the benefits of the design of ubiquitous actuator desribed in my first paragraph over a simple direct-acting actuator? I don't understand why a control valve actuator needs to be so sophisticated.
Scott
"You can marry more money in five minutes than you can make in a lifetime."
Have you read the Eng-Tips.com Forum Policies lately?
Scott
