Type I manhole for valve vault?
Josh S.
Hi all,
I am working on a project in a remote area with limited precast vendor options. Anyone see any problems with using a Type I manhole for a valve vault? Thinking of a 48" diameter vault to house a 24" BFV and air release valve.
not sure what a type 1 is, but 48 inch seems a bit small, unless it is for the operator and air valve only
Thanks cvg. I think you're probably right; may have to go with a 60" MH.
"BFV"... Big Valve? <G>
I assume butterfly valve
Same here... just jokin' been a slow day.
Dik
its a big, beautiful valve
#biggely
You use Type 1's as catch basins for at grade inlets. They are less than 24" square.
Definitely not a Type 1.
Mike McCann, PE, SE (WA)
No problem with it.
Yes, butterfly valve, but I do like BeautiFul Valve. :)
As far as I know we call them Type I around here...
