JSMHA
- Aug 25, 2021
- 4
I am using RAM Concept to design a two way slab with edge beams and supporting columns. Most of the design examples I see seem to run the models with no stiffness reduction factors. Based on my interpretation of ACI 318-19 Section 6.6.3.1 it seems at factored loads the reduction coefficients noted in this section have to be applied. And ACI makes no mention of designing for strength using a moment distribution based on full uncracked member stiffnesses. How do people handle the stiffness factors when determining the moment distribution in two way slabs? Do you just apply the ACI reductions? Does anyone design in RAM Concept based only on full stiffnesses? Is there any code locations i am not aware of that has a further discussion on this?
