KootK
- Oct 16, 2001
- 18,657
Where a flexible structure is placed atop a relatively rigid structure, ASCE permits the use of a two stage equivalent lateral force procedure.
One of the requirements for using the two stage procedure is that the stiffness of the rigid base has to be 10 times that of the flexible upper structure (ASCE clause). I'm having difficulty interpreting that particular clause however. As read, I interpret the clause as follows:
1) Take the flexible upper structure and treat it as though it were fixed at the junction between it and the stiff lower structure. Apply a dummy force to the top of the upper structure, calculate the resulting deflection at the level of the applied force, and work out k = F/d.
1) Take the stiff lower structure on its own, taking no account of the presence of the flexible upper structure. Apply a dummy force to the top of the stiff lower structure, calculate the resulting deflection at the level of the applied force, and work out k = F/d.
3) Compare the stiffnesses calculated in steps #1 & #2 to see if the rigid base is 10X as stiff as the flexible upper structure.
Unfortunately, this method of comparing stiffnesses doesn't make sense to me.
Suppose, hypothetically, that you had a 30 story building with uniformly stiff moment frames from top to bottom (i.e. no rigid 'base' or 'podium'). If you performed this same analysis (steps #1, #2, & #3), you should be able to justify using the bottom story of the building as a rigid base. This, even though the building clearly doesn't meet the intent of the ASCE clause.
So... what's up with that? Have I misinterpreted the clause somehow?
Note: the fictional example that I gave above may well fail the period test for using the two stage analysis. That doesn't really alleviate my concerns regarding the stiffness test however.
Thanks for your help.
KK
KK
