Two more questions ....
Ted (hydtools) has been awesome and helped me design the perfect power unit. Unfortunately, I realize nothing is perfect so I am looking at a back-up power unit. Nothing fancy, just an simple unit that will lift and lower my cylinder if my primary unit fails ( which could happen since the pump/motor and cylinder is out of a 40 year old forklift ). My thinking is to just put a dry break coupler on right off the lift cylinder. If my pump or controls fail ( or even if I just break a hose), I just unplug the main system and plug in the backup unit. This would cover any failure other than the main lift cylinder failing.
So this leads to to two separate but connected problems.
1) The simplest (and I am guessing the most reliable) power unit I am seeing out there the units used for automotive lifts. Small footprint, pump on top of tank standing vertical. 4 gal tanks all putting out 2500 - 2900 psi at about 2 GPM. I have looked at several ( Norther tool (NorTrac), SPX (Stone), Haldex, ebay specials, ....). They are all Chinese built .... all in the $400 to $600 range. Push button (hold on) for up ... no valves, motor runs and cylinder lifts ... some don't even have contactors, just a heavy switch. 220 vac at about 15 amps single phase. Manual valve gravity lower. Not great for a primary unit ( although auto shops use these all day ) but of a backup I think they will be great.
So my first question ... is any brand better than another? They all seem to be about the same. Since they are all Chinese, probably all about the same quality ???????
2) Choosing this pump ( or any similar unit ), leads to an oil compatibility problem.
My forklift has a label saying "Texaco Rando HD-B" ..... can't even find a specification for this on the web. I called Chevron (Texaco), they say the equivalent is Texaco Rando HD 46.
The pumps I am choosing all say ISO 32 or Dextron III ( I checked, Dextron is about ISO 29 ).
So, these two pump require oil one step apart .... 32 vs 46.
The unit is being used inside so I really don't need cold weather capability. The unit will be used only a few times a day for 1 - 2 minutes a day, so I don't need to worry about heating up the oil after hours of use.
Would it be terrible to use either 32 or 46 in both units?
I can use the correct oil in each unit and since each has it's own reservoir and if I switch connections while the cylinder is at the bottom of it's stroke, there would be minimal oil exchanged but it would be nice to use just one type of oil in both power units.
Again I am "guessing" that the oil viscosity is controlled / limited by the pump and not the cylinder ????????????
Thanks again so much !!!!!!!!!!!!
Mike
Mike
