vonsteimel
Greetings,
I posted a question this spring concerning Torsional Vibration & Resonance of a Ducted Fan Power Train Setup.
This is somewhat a continuation of the same issue.
We have a machinery setup powering a ducted fan (see attachment). At first we experienced severe Torsional Resonance and made some changes to correct this. After further testing it was apparent the TV issue had been resolved. Time rolls on and more changes are made for a variety of reasons as with any development project.
Now we're toward the end and there is reason to believe the centrifugal clutch (seen in "setup.jpg"), which was installed to help resolve the TV issue, is no longer needed.
My question is: How can we determine the Torsional Vibration Dampening properties of a centrifugal clutch? There are no locking mechanisms other than friction between the shoe & drum. The theory is that after the clutch has engaged it will help dampen Torsional Vibration by allowing slippage.
For instance, when the power-stroke occurs(no flywheel is used) a load is suddenly applied in the direction of rotation. If this "sudden load" comes in sync with the natural frequency of the shaft, destructive torsional vibration and resonance will follow. With the clutch installed, the "sudden load" applied to the clutch will induce a small amount of slippage before being transferred to shaft thus dampening the vibration.
NOTE: I know this is a complex Phenomenon with many contributing factors & possible solutions. Any replies/suggestions will be greatly appreciated but please keep them related to the core question: HOW TO DETERMINE THE TORSIONAL-VIBRATION DAMPENING PROPERTIES OF A CENTRIFUGAL CLUTCH.
Thank you,
CS
Thank you,
CS
