drodrig
- Mar 28, 2013
- 262
Hi there,
We have a load on a plate we want to turn by 90º. What is the best way to do this?
I thought about using gears. Here the general idea:
We have this grey plate in horizontal position:
We mount the load on the top (just a block to simplify the representation):
We attache four supporting plates (in blue) on the original plate to get closer to the center of gravity:
A frame (in pink) around the system connecting all blue plates is placed:
Two stands (in transparent colour) are installed:
Then comes a pillow block bearing on the stand and a spur gear which is attached to the pink frame (there was a square hole). The shaft is in the center of gravity
And finally a small gear with a cranked handle on the stand:
I didn't calculate anything yet. First validating the idea, this is the easiest way I came up with to turn this
What do you think?
What do you think?
