Guardiano
- Nov 11, 2008
- 118
Hi forum members,
In the case of a back pressure turbine, the output depends on the delta P between the inlet pressure and the exhaust pressure.What factors determine the efficiency of the turbine particularly on the exhaust side? I am on a site where the steam demand on a turbine has increased but the power output is significantly the same.
Thanks.
Guardiano
Thanks.
Guardiano
