Nordic119
- Apr 2, 2009
- 2
Hi
We have an existing 12" well casing that sticks out of the ground about 10' when they installed it. During the wet months, the well is artesian & under about 5-7 lbs of pressure.
We were wanting to mount a vertical turbine pump, with a linehshaft, column & bowls down into the well...inside the casing (down to about 60'). We were going to pour a raised pad (24"x24"x12") at grade, & mount a surface discharge head with a flanged connection to the column & a sole plate over the pad.
My question is, can we just cut the well casing just below the top of the pad? If so, will the base of the discharge head & sole plats seal the well casing from leaking when the well is artesian? Or do we somehow have to put an flanged adapter on the well casing after we cut it & mount it to the discharge head somehow (in addition to mounting it to the column)?
Thanks.
Thanks.
