Without any other information I would say to check the minimum flow rate for your turbine meter. This minimum flow rate can vary between 70-120 gpm depending on the size and type of turbine meter. Below this level the turbine meter will not measure accurately. If you have multiple loading arms being fed by the same pump you must be sure that either the pump is sized correctly to provide sufficient flow when all the loading arms it feeds are being used, or have your terminal automation system only allow the maximum number of arms to load at one time based upon what your pump is capable of providing. In short, check both your pump and meter specifications and be sure you are meeting the minimum flow requirements.
-Taylor
