First post for me here (but have read hundreds)
This idea has been rolling around in my head for several years now. I know that about 30-40 years ago, Chrysler (and perhaps others?) was experimenting with turbine engines in cars. I remember a Speed Channel (when it was Speedvision) epdisode enterviewing a guy who owned one of these. It idled at 20,000 rpm, redlined at around 40,000, had something like 125 hp and 425 lb-ft. (Depending on which model you look at, hp tended to be 100-140, and torque 375, 425, etc).
The obvious problem (beside gearing it way way down) is the fact that a turbine engine is best suited for constant use under load, rather than on-off acceleration. So you either have to make a big turbine, use a lotta gas the 90% of the time you don't need power, and have the performance, or put in a more efficient turbine, but have no power when you need to pass / pull away from a stop / hill climb.
Seems to me the solutions is turbine + CVT...the infinite gearing would allow you to stay at peak torque RPM nonstop (great mileage), and the super-wide gearing would let you multiply that torque into power when you needed it.
What do you guys think? I wonder why, with all the expensive hybrids being built, none of the manufacturers have tried this recently.
Northwestern University Engineer, class of 2007
