B
B0ND
Guest
Hi, I'm in need of some advice and help. Currently I'm trying to design and analyze a tubular race car frame. My first design is shown below:View attachment 2248
After I finished this design I tried to analyze it using Mechanica to find the torsional rigidity. When I started my Design Study, Mechanica gave me an error stating that my geometry was invalid, and then proceeded to take a while doing (apparently) nothing; I say this because when I tried to view the results later there wasn't anything there.
I believe that the reason for this error was the way I modeled it, which was to first create datum planes, then datum points, then sketches between the points, then swept protrusions along sketches. This method gave me lots of overlap of my tubes (which I didn't think would be a problem at first....guess I was wrong).
So I was wondering if there is any way for me to fix my model easily and quickly so that I can perform analysis? Also since I will be creating more/updated models, is there a method you have found best for doing these sorts of designs? (I posted about this in the Modeling forum as well)
Also of note, I have access to: Mechanica, ANSYS 10, MSC Visual Nastran 4D and MSC Patran. Which of these programs would you recommend for my analysis? I'm most familiar with Mechanica, barely touched Nastran, and never used ANSYS or Patran.
Thanks in advance!
Eric
Thanks in advance!
Eric
