vmirat
- Apr 4, 2002
- 294
I have an HSS 10x10 beam sitting on top of several HSS 10x10 columns, forming multiple tee connections. I'm thinking I should check local buckling of the tube steel beam webs as a result of the concentrated load from the column. I was going to use Section J10 of the steel manual but this seems to be focused on wide flange sections, not HSS. Does this section work for HSS?
Just for clarification, the top of the column will have a bearing plate that connects to a plate welded to the bottom side of the beam and is intended to be a pinned connection (the column acts as an inverted pendulum).
