Not sure where to post this.
I am looking for manufacturing advice for crimping a tube with an internal end cap. The OD cannot dimensionally change more than +/-.002, and forming the crimp must not move the internal end cap more than +/-.005.
Tube: .450"OD with .030" wall thickness, 17-4 steel
Crimp: ~.090" wide with .414"OD
I was told that roll crimping this feature may impart a twist on the OD of the tube, so I am looking to form this some other way. My concerns are that any method will deform the OD which is very critical. Internally we discussed that the tube could be crimped with a 2-part clamp about 50%, then rotated 90deg and then fully crimped to reduce deformation.
Looking for any advice or suggestions.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
