Tube bending ?
Jamaz17
Automotive
Aug 20, 2004
131
Hey everyone,
I have to bend a piece of round steel tubing 20 deg with an OD of 1.75in and a wall thickness of .125in. Does anyone know what formula I might use to calculate the force I would require to bend this pipe to these specs ? I'm trying to spec out a cylinder but I'm not sure how much force I will need?
Thanks for the help.
-James
You should be able to bound your problem by treating it as a beam and solving the beam equation using the end conditions that best approximate your bending fixture.
Bring back the HP-15
Assume yield stress over the whole cross section to find bending moment (approximately). If you have a stress-strain curve, guess you could come a bit closer.
