Trying to re-add a centerline... 1
DerrickH
28
I have a detail drawing where I've added a CL to a feature by selecting "Centerline" from the Annotation menu, and clicking on two edges. The CL has since been deleted, and when I try to add it to the feature again I can't. I get the message "There is centerline existing between between the selected entities." Has anyone ever had this issue before?
Derrick Hochgesang
Specials Project Engineer
Ah-ha! If you selected a face when setting up the centerline, there are others in the view which may not be apparent to you. Use the selection filter to catch and delete all of them and start over.
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
I turned on the filter to select only CLs, and made a selection box after zooming WAY out on my drawing. Deleted all CLs and still getting the same message. I can used a sketched CL, but I always hate having to if I can help it. Just frustrating especially when I had one on there once before.
Derrick Hochgesang
It's acting like the CL has been hidden.
I've just done a quick test and hidden a CL and am getting that same 'error' message when trying to create another CL ... but I cannot find a way to select the hidden CL to unhide it ????
OK ... got it;
View > Hide/Show Annotations
Any hidden annotations will show greyed out
Select the line so it shows black
Hit enter
Done (or should be)
THANK YOU! LOL, I knew it had to be something as simple as that... it's just a task sometimes trying to figure out where to look for that one little thing. I hate those things that "switch" over on their own and create problems in the future!
Thanks again!
Derrick Hochgesang
