BAGW
- Jul 15, 2015
- 392
Do we need to brace the tension chord of the truss based on AISC appendix 6 requirements to satisfy k=1 from compression web member design?
Was reading through the research paper from Fischer (1983). Seems very conservative to me as no tension diagonal contribution is considered. Wont the tension diagonal member stabilize the bottom chord against the compression vertical force member?
Any thoughts on bracing the bottom chord for the vertical member compression force?
