We have a case where we are trying to "fine tune" a weld of a structural member to a plate such that the weld will fail at a specific load...truly fail.
The reason is we don't want any of the adjoining connections or members to fail first...just the weld.
This is somewhat like seismic design where you strengthen up brittle connections and make sure that more ductile members will go plastic and yield first to avoid a brittle failure.
To do that we use an Ry or Rt factor on member material strengths to ensure that we don't underestimate what our true strength is.
For example we find that A36 steel uses an Ry of 1.5 meaning instead of Fy = 36 ksi it is really 54 ksi.
In our case, we are doing the opposite - trying to undersize a weld such that it fails at a specific range of loading so as not to overstress, and damage, adjoining connections.
So...the question....is there a comparable Rt value for E70 electrodes in welds?
If I use 70 ksi - that is listed as the "minimum" ultimate strength. What is the true ultimate strength?
Or does the base metal let go way before that?
