I've been tasked with designing an inspection gage to check the attached part. The gage needs to check the locations of the 4 tips
within a true position tolerance of 0.35mm and no MMC in the feature control frame is given on our customers drawing. This part fits into 1mm sized PCB holes and then is soldered. The problem I see with this is that if I design the gage holes to MMC of the part and the 0.40x0.24 flat on top is small (but still in tolerance), than the gage will pass bad parts. If I make the gage hole smaller I could be throwing away a lot of parts that meet print, if the pin tips are at max condition. I do not see how this is realistically possible and think other means of inspection would be a better fit for this. I thought that you needed MMC in order to design a gage. Has anyone had to do this before?
