classIdiv2
- Jun 2, 2011
- 1
How could I get a "true" motor running indication? I was using the motor starter N.O. contacts but since my control circuit is 24VDC and my motors are running at460VAC so it is not a "true" motor running indication when 460VAC is down. My client also asked a current indication for the motor on the door.
Where can I get a device which can show the running current on the door but also has a dry contact output to indicate if there is any current has been detected? I don't want this device to have any over-current or under-current or any sort fo protection. Just a simply current amps indication and a relay output or dry contact output to show motor is running or not running.
