Our company equips trucks with required equipment and structure for different applications.
We have a truck mounted with a 10,000 lit (2700 US gal) Poly Propelene tank (External Dimension height: 1600mm X Width: 2500mm X Length: 2800mm). The tank is mounted on a frame under the tank using bolts which are tightened directly on to the Polypropylene tank. This frame is mounted to the chassis through rubber flexible joints. There are no other supports or fixtures holding the tank except the above.
Our Engineering department claims that there are no issues and the type of mounting is sufficient. Unfortunately there is no study or calculation supporting conditions like when the truck applies a sudden brake, takes a sharp curve or drives off-road. We did a validation by conducting a road test, however we (as quality control) are looking for some supporting calculations which can ensure safety of the mounting system in the above conditions. Would appreciate if someone can throw some light on this. Thanks
