Having trouble and wonder if anyone can suggest anything.
I have some bearing slides, the assy of which are set up so that travel along them in unconstrained.
At the next level - X-Y drive - I have 2 of these slides set as adjustable assemblies and all is good. At this level I've again left them free to travel by suppressing the relationship in the relevant direction.
Next level assy, I can't get them to adjust. I make the X-Y drive assy adjustable in the feature tree. Put a constraint in to control their travel but it defaults to a floating relationship. If I switch it to one I can put a dimension in, I can enter a new dimension, the new dimension shows, but the parts don't move.
I tried importing just the X-Y drive to a new assy (in case I'd got conflicting assy constraints somewhere) and couldn't get it to work. The parts attached to the XY drive that should be showing 'unconstrained' when I make it adjustable mostly don't - while a couple it shouldn't effect have the red lightning bolt showing they failed.
The X-Y drive is the first part in the assy so is grounded.
The relationship I'm trying to put in is between components of the XY drive (between limit switch and stop) - is this the issue? Does the relationship need to be to something not in the adjustable assy?
