Trouble Making Variable Radius Fillet
superart
46
I'm trying to get the edges of this hole to have a variable radius fillet. I need it to be 0.2m at the points where the rim of the hole intersects with the right plane, and 0.05m at the points that are perpendicular to the right plane.
The problem is, when I try to do it, I am not getting those points where I can set what radius I want. I think it has something to do with with the hole being slanted, but I might very well be wrong. It works with a constant radius fillet, but I need it to be variable.
I would GREATLY appreciate any help you guys could offer. thanks in advance.
WOW!!
Thank you so much. I never would have thought to do that.
