swearingen
We have a client with monorail hoists of 1 and 2 ton capacities going in a new industrial structure. The client is insisting that the structure be designed for the weight that will be lifted (1000lb for the 1 ton, 2400lb for the 2 ton), with the weight of the trolley and hoist included, of course. Our position is that the structure should always be designed for the rated capacity of the hoist (plus trolley and hoist).
In their defense, CMAA 74, the only standard we know of that would cover something like this states the following:
"3.3.2.1.3 Lifted Load (LL)
The load cases listed under sections 3.3.2.5.1 through 3.3.2.5.3.3 use LL in them. There is a glossary, but no definition of "working load."
This can be read to mean exactly what they're saying - that it only has to be designed for the actual load and not the capacity of the hoist. That said, the industrial environment is often a harsh one and machinery can (and will) be abused. Designing the structure for 50% to 60% of the rated capacity of the hoist itself is folly to me and at the very least, irresponsible.
Am I off base in my position?
-5^2 = -25 ;-)
The lifted load consists of the working load and the weight of the lifting devices used for handling and holding the working load such as the load block, lifting beam..."
-5^2 = -25 ;-)
