Trimmed Sheet Tolerance Issue:
NX9 - Windows 7
We are receiving unusual results with this command and we can't seem to understand why. The curves are projected onto the face from a continuous end-to-end chain of curves.
When we use the Trimmed Sheet command on this patch, we get these splat-errors at a tolerance of 0.001.
When we change the tolerance to .0001, it works correctly. This tolerance change seems backwards though.
When we change the tolerance to .01, it appears to work correctly but cuts off the top portion of the sheet. The slice cut off at the top seems to correspond to the splats from the .001-tolerance. It also cuts off the bottom right hand and left hand portions.
Denis Huskic
Nx 8.5, 9
Windows 7
NX9 - Windows 7
Denis Huskic
Nx 8.5, 9
Windows 7
