Trim No. and Leakage Rate in Globe / Gate valves 1
MY
Is there any relationship between trim no. specified in API 600 and leakage rate specified by DIN 3230-3 or any other standards in a globe or gate valve?
Thanks.
TRIM NO ACCORDING TO API LIKE 1,5,8 ETC ARE RELATED TO DIFFERENCE IN HARDNESS / TO AVOID GALLING + SERVICE TEMPERATURE. NOT SURE IF RELATED TO LEAKAGE
There is no relationship between the trim number and the leakage rate. The trim number simply defines the materials of the two mating surfaces.
Leakage rate is determined by: type of seating i.e, soft-seated or metal-seated; type of valve i.e. gate, check, high performance butterfly, etc; surface finish; and other factors.
Take a look at :
API 6A/598
for leakage rates.
here is a simple look at the most common leakage classes and how valves are tested to establish that leakage rate.
ANSI CLASS Class III
Maximum Seat Leakage 0.1% of rated valve capacity Test Conditions
Air or water @ 50 - 125 F. 45 - 60 psig or Maximum operating differential pressure whichever is less
ANSI Class IV Maximum Seat Leakage 0.01% of rated valve capacity Test Conditions
ANSI Class VI Maximum Seat Leakage 1" Port Diameter
0.15 ml per minute or 1 bubble per minute
Test Conditions
Air or Nitrogen @ 50 - 125 F 50 psig or Maximum operating differential pressure whichever is less
Simplified Chart for most popular leakage classes. For complete specifications refer to ANSI/FCI 70-2
This should at least give you a start on leakage classifications.
