hi,
Typically, when I place an xref in a drawing, I am able to use lines in the xref to trim or extend lines in the "host" drawing. e.g., I start thr trim command, and if I select a line in the xref as the "cutting" line, only that line is highlighted, and I complete the trim operation, similar to what you find using a block the same way.
Right now I'm working on a drawing I created from my standard template, but I can't trim with the lines in my x-refs.
Is there a system variable that controls this?
any help appreciated.
sundemon
sundemon
