ejm211
Automotive
- Dec 20, 2006
- 6
I'm new here so stop me if I'm asking an obscene question.
I hear all the time how guys in a front engine rear drive setup are relocated or modifying the motor mounts to put the engine a few inches further rearward in the engine bay. This is mainly done to improve front/rear weight distribution. My question to you, oh knowledgeable ones, is:
What kind of problems will I face designing new engine/trans mounts to move a transversely mounted fwd engine 3-5 inches rearward. This car will see both drag strip and autocross and is a general street fun car. For drag racing, moving this particular setup rearward would actually concentrate the weight of the drivetrain over the front tires, improving traction. For autocross, this will greatly improve the 65/35 f/r weight distribution; with a 2300lb car and the engine and transmission combo weighing right around 400lb, that's a nice chunk of mass.
The few problems I can think of would be:
Halfshaft angle: Obviously, putting the transmission 3-5 inches further rearward will increase the halfshaft angle between the trans and the front hubs. How will this affect performance and wear?
Shift linkage: This car uses two bars, one being a shift rod and the other being a stabilizer. Being a hollow tube with relatively generic ends, remaking these slightly shorter shouldn't be too much of a problem.
Thank you for your time and I appreciate any opinions/ideas you may have to offer. I look forward to your replies.
Eric Mills
Eric Mills
