Transparent body................ 2
CAD2015
Computer
Jan 21, 2006
2,054
How could I make a body transparent (in an Assembly), for a better visualization of the other components?
Thank you
CAD 2015
If you go to the body's properties (right click on the body in the tree, select "properties"), there a transparency slider under the "graphic" tab that may work depending on exactly what you need. I think you can make things behave a little differently depending on if you apply the transparency property at the body, part, or subassembly level in the tree, although it's been a while since I've played around with this so I might have that wrong.
Stick,
That's what I was looking for.
Thanks a lot!
[2thumbsup]
CAD 2015
Use your graphic properties toolbar which is available in every workbench by default.
2nd menu is opacity.
