Transonic Flow without Wings
zdas04
I've tried to calculate blowdown times for pipelines for 15 years with pretty miserable success. I can predict the end of choked flow with pretty good success, but the flow after the line reaches the critical pressure has always been way off.
I recently found an equation for the sub-critical flow, but found that the mass flow rate at Mach = 0.99999 was 66% of the mass flow rate at Mach=1.0. I've spent the day today digging through all the compressible flow material that I can find and every discussion I can find suggests the sub-critical flow equation (incompressible) probably eases into applicability between Mach = 0.6 and Mach = 0.8. In the missing region, the flow is "transonic" and is sort of sonic-ish and sort of incompressible-ish.
Everything I can find about transonic flow is focused on transonic behavior on an air foil. I don't have an air foil, just a line blowing into the atmosphere. Anyone have any suggestions? [Host hands over a stack of bar napkins and a grease pencil]
David
Well, I finally decided to stop searching for something that doesn't seem to exist and started playing with arithmetic.
I took the first and second derivatives of the sub-critical flow equation (with regard to upstream pressure) and found that the first derivative (which looks kind of like a hyperbolic decline, but it isn't log-log straight) is approximately a straight line (second derivative = constant) for the first 14% below the critical pressure. I ran it for a half dozen atmospheric pressures and the number kept being about 86% of critical pressure. I'm taking that as a physical property and drawing a line from the critical flow end to the sub-critical at 86% (it should be an "S" shaped curve, but that would imply more science that I actually put into this).
David
The gas mixture would have to be exposed to about -40oC at your max. pressure to condense out any liquid CO2, so that doesn't seem likely unless it is near one of the poles.
I've never been let down by the age old advice:
1. 10% > dP use incompressible with inlet or outlet conditions
2. 10% > dP > 40% use incompressible with an average of inlet or outlet conditions
3. dP > 40% use compressible methods
But being off by 9X makes me think something is going on with an accumulation and a phase change or something.
I wonder if CH4 or CO2 has an affinity to adsorb onto CS and/or rust? A Google search on each had lots of hits. Too many to get a feel if it's real or not. I suspect CO2 more than CH4. A monolayer of molecules slowly desorbing may drag things out quite a bit, and you got lots of surface area there!
My mind immediately jumped into problem solving mode, wanting a lab, steel wool, a balance, a containment vessel, and 150 # CH4 and CO2, but . . .
Good luck,
Latexman
Being off my 9X actually meant I had some really lame math that I got from someone else (who got it from someone else, etc. back 30-40 generations before someone stopped to check it out) and didn't check out. When I look at it today, it still embarrasses me.
David
