I checked the USPTO website, and found 3 patents under the company name.
US7,444,230; October 28, 2008
Fuel injector having algorithm controlled look-ahead timing for injector-ignition operation
Abstract:
The present invention provides an injector-ignition fuel injection system for an internal combustion engine, comprising an ECU controlling a heated catalyzed fuel injector for heating and catalyzing a next fuel charge, wherein the ECU uses a one firing cycle look-ahead algorithm for controlling fuel injection. The ECU may further incorporate a look-up table, auto-tuning functions and heuristics to compensate for the rapid rotational de-acceleration that occurs near top dead center in lightweight small ultra-high compression engines as may be used with this invention. The ECU may further ramp heat input to the injector in response to engine acceleration requests and, under such circumstances, may extend its look-ahead for up to four firing cycles.
Inventors: Cheiky; Michael C. (Thousand Oaks, CA)
Assignee: Transonic Combustion, Inc. (Camarillo, CA)
Appl. No.: 11/692,092
Filed: March 27, 2007
US7,546,826; June 16, 2009
Injector-ignition for an internal combustion engine
Abstract:
The present invention provides a heated catalyzed fuel injector that dispenses fuel substantially exclusively during the power stroke of an internal combustion engine, wherein ignition occurs in a fast burn zone at high fuel density such that a leading surface of the fuel is completely burned within several microseconds. In operation, the fuel injector precisely meters instantly igniting fuel at a predetermined crank angle for optimal power stroke production. Specifically, the fuel is metered into the fuel injector, such that the fuel injector heats, vaporizes, compresses and mildly oxidizes the fuel, and then dispenses the fuel as a relatively low pressure gas column into a combustion chamber of the engine.
Appl. No.: 11/692,105
US7,657,363; February 2, 2010
Fuel injector having algorithm controlled look-ahead timing for injector-ignition operation. (Same as US7,444,230)
Abstract:
Same as US7,444,230. Claims are different, however. Maybe a continuation. Haven't checked.
Appl. No.: 12/237,302
Filed: September 24, 2008
