transmission loss calculation
rotia
ES
Hi, I´m sttarting with the software LMS Virtual Lab an d I need to calculate the transmission loss of a simple panel. My problem is that I can not find any tutorial about this kind of analysis.
So please, if you know something about this answer and let me know,
thank you.
[input-output]/input is a typical approach
TTFN
FAQ731-376
Be careful to understand exactly what the desired result is and how your measurements contribute to its calculation. Don't just press a button marked "Transmission Loss" and assume that your combination of test equipment and sensor measurements will let the canned computation (usually based on pressure measurements) provide a sensible answer.
- Steve
