I recently had a contractor doing ratio tests on our transformers but they were using the reference capacitor method instead of the conventional voltage method. They basically used a capacitor of known size in series with one winding while applying high voltage (11KV) on the other winding (HV). The ratio of the ref capacitor/measured capacitor was the calculated turns ratio N/n. I simply don't get the concept, could someone please explain this relationship.
