I've got a question concerning XFMR ratios and excitation. Assume a Wye/Delta 138kV to 13.2kV GSU (138kV/13.2kV = 10.455 turns). Are there any issues with using a Wye/Delta 138kV to 13.8kV GSU, if I adjust the taps to closely match the 10.455 (set tap at 144,900kV to yield 144.9kV/13.8kV=10.5 turns). Matching ratios seems the obvious thing to watch for, but are there any possible issues with under exciting the core, operating it at 13.2kV instead of the designed 13.8kV? Losses may change?
