I need to clear up a question
When using three single phase transformers arranged in a Delta - Delta configuration i.e.
3 - 15KVA 480/240 transformers connected into a three phase delta arrangement - what is the maxium current that can be safety drawn across each phase i.e. X1 - X2, X1- X3, X2 - X3. Each transformer is rated at 62 amps if used a a single transfomer which would indicate that 62 amps is the maximum that can be pulled across any phase. A three phase transformer rated at 45KVA would provide 108 amps at 240 volts.
My customer insists that the standard capacity chart shows in a three phase arrangement each 15KVA unit would be capable of providing 36 amps with a combined total of 108 amps.
What is correct?
What is correct?
