transfer PRO/E MODELS TO ANSYS
  • Thread starter Thread starter ashokmalve
  • Start date Start date
A
ashokmalve
Guest
I am ashok user of prowiledfire2.0 but i got some problems
in transferring the models from the proe to ansys
if it works then for that meshed models ansys is working and showing some errors..
can we do the analysis and animation and plotting of graphs same as in ansys in proe
pls advice me
hi ashok
i am uday from mumbai.i am also pro/e wildfire 2.0 user.if u want to read results like ansys(i.e general postprocessor) in pro/e it is not possible.in proE you can do prepocessing and solution steps but for GP you will have to select solver of ansys,nastran etc.
regards
uday
91 9892 858268
mumbai
ashok/uday,
If you have ANSYS Workbench with DesignSpace then you can do what you want. Not only can you do the analysis and animation and plotting of graphs same as in ansys in proe but you will have bidirectional associativity.
Israr
kya dhakar bhai
kyon pareshan ho raha se re..google par search mar, jarror kuch mil jayega. bade afsos ke sath kehna pad raha hai, mune kadde anysys use nahi kara se...
Israr said:
hi israr
thanks for guiding me
regards
uday
