Trailing dimensions 1
jimp178
GB
Hi Is there any way to add trailing dimensions with out inserting them manualy.
For example 80.00 instead of 80 which I seem to be getting.
Is there a switch in the settings?
Thanks in advance. JimP
Shouldn't this be accomplished by setting the precision of the dimensions? Try going to Tools, Options, Document Properties tab, Units and then set the number of Decimal Places to 2.
- - -DennisD
none of the above seem to work. Changing the precision to 2 will imput 80.01 if that is the size but for 80.00 it imputs 80. i am working in Ansi settings have tried ISO with the same results
Thats for you quick replys. Jim
What units are you using? If you are using metric units, you won't get trailing zeros. If you use inches, you should see them. "The attempt and not the deed confounds us."
If you go under your Tools, Options, Document Settings, then Units, what is the Decimal places set to? In your case it should be 2.
BBJT BBJT CSWP
I am using Metric units
Decimal places are set at 2
JimP
Hi Jim,
Please try...
Tools > Options > Document Properties > Detailing...
Trailing Zeroes use Show...
You probably had it set to Smart or Remove..
Hi Scott,
You must be thinking of leading zeroes, trailing zeroes aren't controlled by the standard.
cheers,
Joseph
Thanks josephv your a STAR.
Thanks to all for your help JimP
Damn,
I just found that. BBJT CSWP
I tried that with feet and inches - if it is an even number of feet, the inches don't show. "Show" doesn't seem to help in ANSI or ISO. I tried changing the precision too.
What am I doing wrong?
Tom S.
