Jobst
Chemical
- Mar 5, 2008
- 32
Hi All,
Can anyone point me in the right direction for dealing with trace components in a gas mixture, and whether these need to be taken into account when determining temperature code for equipment?
E.g. I have a gas where the bulk components would warrant T2 (<300 °C). However, there's <100 ppm of a component which would warrant T6 (<85 °C) if it were a pure component. There is no way for the trace component concentration to increase beyond a few hundred ppm.
Somebody is asserting that because this component is in the gas, we must specify T6 for all equipment in the area. This seems a little over the top to me. If this was a flammability range determination, I'd do a calculation of the mixture flammability range, rather than using pure components, and use the mixture limits for design (with a healthy safety factor). Without any discussion of how to deal with mixtures in the standard, it seems that this person favours following the standard to the point of absurdity, and asserts that even 1 ppb of this substance would warrant a T6 rating, even if the remaining components were completely inert.
Any help appreciated!
