I am trying to find a replacement plastic material with the following properties:
1. Injection Moldable
2. Shore A hardness between 30 and 45
3. UV-Stable
4. Temp. range of -40F to 180F
5. No mineral oils used in construction
Tried using Krayton (DYNAFLEX G7930-1001-0) and Santoprene 8211-35; which both have the physical properties we need; but ended up leeching oils past 80F.
Want to use this material in a form of a molded gasket between 2 fiberglass profiles--and are having issues with the mineral oils from the current material (Krayton) leeching into the fiberglass over time.
Need some suggestions on material options for this gasket (it has a failry complicated 3d profile).
3. UV-Stable
