Jmeng1026
- Jun 11, 2018
- 61
See the attached detail. The contractor used purlins instead of plywood so the 4' of fire retardant plywood was not installed. So a fire could burn up and over the fire wall due to the purlins. Is there a way to remedy this other than removing the metal roof and plywood and installing the four foot fire retardant plywood? Some kind of fire caulking?
Thank you for the help.
