Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
When officers finally caught up to the two cars, they ran the plates on the Saab and discovered its occupant, identified as 32-year-old Dante Brown, had a warrant out for his arrest in DeKalb County, Georgia.
The wheels don't turn (as in steer).I think they allow the front wheels to turn when locked to the dolly.
The Saab is front wheel drive and unless a manual gearbox should not be towed flat. Why tow backwards ?
I thought it did but couldn't see it on the photos I found but makes more sense to do thatThe wheels don't turn (as in steer).
The assembly on the dolly which supports both wheels is pivoted to allow for turns.
Thank you for double checking.Range must be very limited on pivoting top plate
