Hello to everyone!
Due to incorrect parameters setting during the sheathing/jacketing process of a medium voltage, a big part of the produced cable has a total diameter exceeding the one originally stated to the end user by nearly 10% (67 mm compared to 60 mm). As if that wasn't enough, the length produced is less than what the customer requested for a few meters ...
We plan to contact the end user to see if he will accept the produced length and to let him know about the difference in overall diameter.
I was thinking how a 7 mm difference could affect the installation/laying process or the end user:
1. if the installer uses cable rollers to lay the cable, maybe it would not fit the roller already purchased based on submitted data, assuming that the MV cable may be the biggest diameter in a
typical project.
what are the tolerances in mm for a typical cable roller?
2. if the installer uses a pulling head, this should be no problem since for single core cables it is usually fastened on the metallic part of cable.
3. if the installer uses a stocking type pulling grip, normally they have a tolerance of 20-25% in relation to the nominal diameter.
4. For the cable glands of the switchgear panel and the electrical load termination box, we are quite marginal to the commercially available tolerances.
I understand that in the case of the termination box, this can get really bad due to space limitations, ATEX enclosures for motors not allowing drilling bigger nut threads etc.
The above are some thoughts I have made before communicating with the end user. It would be great if anyone more experienced could comment on those or notice any important details omitted!!
postscripts
My job is in the design/tendering/commercial part and I don't have enough information about the mistake that led to such a deviation in the diameter.
Thanks in advance,
G.P.
typical project.
postscripts
Thanks in advance,
G.P.
