Dear Sir/Madam
I wonder that the area of total condenser(TC) should be greater than partial condenser(PC) or not.
I got a weird htri result: the area of TC I got is less than the area of PC.
(Pls see the process drawing is attached in the post)
The air/solvent is purged and dosed in the polyester acrylate reactor, and vapor to the top partial condenser (PC) to condensing,
and then to be condensed further in the total condenser(TC).
Furthermore, the PC is cooled by cooling water, and heated from 30C to 40C at inlet P=4.033kg/cm2A.
Lean air (including T2(toluene),C2(cyclohexane),and H20) is cooled from 110C to 50C, and vapor fraction is decrease from 1 to 0.046.
Then, the lean air in the TC is further cooled by chilling water, and chilling water is heated from 10C to 15C at inlet P=4.033kg/cm2A.
Accordingly, the lean air is cooled from 50C to 30C and vapor fraction is decreased from 0.046to 0.03.
There is another issue bother me : the flow rate of the air/solvent required to be into the PC
should be equal to the same flow rate that is further condensed in the TC or not.
Cause I used the same flow rate to input in the HTRI's hot fluid properties and process condition for the PC and TC,
I wonder it may result in this illogical answer (TC area < PC area)
(HTRI is attached in the post)
The TEMA type AES is used here in case any leakage happening, but there is a wired htri warning message:
TEMA Front head location: the value enters was not recognized. “Bottom" will be assumed.
I really appreciate your kindly advice in the query.
Thank you very much.
