Tortion
  • Thread starter Thread starter engjs2
  • Start date Start date
E
engjs2
Guest
i want to solve the tortion problem of step rod whose larg dia end is completely constrained, i have analysed the same problem in ANSYS but i have no idea how to solve the very problem in Pro-E.could any body help me?
It sounds like you want to do a stress analysis? Pro/E by itself cannot do this - you also need Pro/Mechanica. After the part is complete, you need to assign materials, apply connstraints,apply loads and then runthe analysis.
Use the TLAP (Total Load At Point) Load to apply torsion since solid elements do not have rotational DOF / moment loads:
See here:
Suggested Technique for Defining Torsional Moments on Cylindrical Shafts
http://www.ptc.com/cs/cs_24/howto/mst844/mst844.htm
burnsp & miya!
thank u very much for ur information
Regards.
miya!
you have given me a very benificial link it will be very helpful for me.
thanks
regards.
